sudbury area ont canada
Welcome to the forum! :)
A few useful things to get you started:
  • The current Mini 3 Pro manual can be downloaded here (it doesn't come in the box).
  • You can find other commonly used downloads on the Mini 3 Pro downloads page.
  • This video covers all the basics of the Mini 3 Pro.
  • Your drone batteries will last longer if you use and maintain them like this.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
Hello from the Crossroads of America zeker.
Welcome to the Forum. :cool:
complete newby here.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum. We look forward to your participation and your view of the world.
From California, US - Thanks for joining us @ MP @zeker! Be sure scroll down the forum list to find the Mini3 Pro threads.
Reactions: LoudThunder
jhgfdhjrye
