new to forum, new to drones
mavicpilots.com
Ok, you've give us a lot of info about yourself, but I have to beg the question… You list your age as 84, but you say your wife is still working as a Flight Attendant… You must have "robbed the Cradle…" LoL…
Now, back on point… As a New Drone Pilot (Your Words…), there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
The
Mini 3 (if flown Light) is not required to be registered, the
Air 2S would have to be registered…
When I first started flying I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
\Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the
Mini 3 and the
Air 2S, including the User Manuals.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Air 2S related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
