titan atlas with the 9db antenna?
let me know what you find out! did you find a meter? its worth a try to check voltage
Still, even if I get this to work[emoji848] I like my rotating pole idea, not portable but great for house flying.
Every time I have idea I spend and spend and spend some more money on this hobby, but I have to say I'm having fun. (Remote ant. Pole) set it happing.
I just received my switch system from Titan, how can I test amps, I don't think they are working. If I use just the whip ant. (9dbi) I go just as far as amp with whip ant. That should go way further I thought because of amps boosting.
I like to see someone amp. the mavic original ant.
ok cool after all this and we don't find the problem if I was you I would call titan..
ohh yes I know what you mean there! if you want to do that pole you would be better off with a panel antenna for that
a directional antenna is what you will need for that pole
Reactions: Rnl
Just so anybody that's reading I think I have 1 bad amp. swapped the cables around so that that left remote ant. was going through right amp. and it works way
Better, so I believe my left amp. is bad.
Called Titan explained the problem sending me a new amp. Very easy to deal with, like dealing with Titan great customer service.
that is good to hear! yes I did hear they have great support!
lol mater of fact I just got up at 5am as they say earlier bird gets the worm lol
I'm going to try the directional ant. Today now that I know which amp. to try it with still won't have one on rx side but should give me an idea.
I was going to ask you how much further can you go with titan?
Haven't got to fully go way out, but I can say it's going to be better, went out 2.5 miles then dropped down to 75 feet, never could do that before had to be 150-200 feet hi before. Wind here is killing me trying to go past 3 is eating battery.
that's a good sign! let me know how far you can go! as for storms not yet but it may snow today :( well that is what they are saying
Marcc
