titan atlas with the 9db antenna?
Not a whole lot and I'm flying from second story
Couple of tree lines but bare can see through them good
Family trying to move in on my drone time. Takes a little longer.[emoji3]
Really would rather not, she's to pretty now to hang anything but extra batteries.
was you able to find a meter? also did you hear back from titan?
ok yes you should see some improvement... hummm how far can you go with just the 9dbi antennas?
Could do that with stock but needed 100 feetore alt.
did titan get back to you? and was you able to get a volt meter?
ok we post at the same time ok on that did you find a volt meter yet?
@Rnl
did you find anything out? and was you able to get a meter?
They think because antenna to close to house, losing signal. Going to try different area, or mount them on roof and see what happens.
you cant use that type of meter to test RF output but you can test to make sure the amps are getting the right voltage
did titan get back to you yet?
They think I'm to close to house holding remote out the window he thinks I'm losing signal, going to try different area when weather breaks.
I would assume that is the same way you did it with the stock setup? hum you would think amp would give ya a little more in that situation
Reactions: Rnl
haydenb400
