Not sure I just ordered the switch should be all I ever need.
It does but order other as well. Hope they ork good alot of different ways you can use it. Also ordered longer cables so I can mount antennas out side,sit in my gun room ( climate controled )fly out the window.
If you're going to make your own and mount it outside, check the mods section. There's a guy in there who built his own using 8w wifi amplifiers other parts. He get's fantastic results and you can build these pretty easy. Also, you can mount a wifi amp on the drone. I have a 4w amp and get 3 bars at 8.5 miles. I have an 8w amp coming this week that I'm going to test mounted on the drone.
Yeah I am. I thought that too but I seem to get much better video signal with my phone/controller than with the goggles. At any rate, if I can get good signal from the Mavic without having to do a controller mod, that's a win as I see it. 45$ for a wifi amp vs however much for a controller mod and end up with a bulky controller.
I haven't tested it very thoroughly yet. Maybe you're right though. Maybe the latency and poor signal are just more obvious with the goggles cause you can see everything so clearly.
Smooth mode is awesome. 60fps looks great. I usually fly in normal HD mode though.
