Tripltek mount?
The only negative is that installation of the Baldur on the controller requires the installation of 4 fairly small thumbscrews. You can see 3 of them in image 0256 (silver in color).
I noticed that as well and I modified my case to accommodate the controller with it attached since I don't like fumbling around with stuff when I want to fly.
Of course there's no room for the Tripltek tablet in the case, so I fabricated some aluminum and fastened it to the case with 3m heavy duty "Velcro" to accommodate the tablet and launch pad.
anyone with the tripltek pro have an issue with the tabs that say button customization in the software, When I tap the recenter gimbal button to change it, to a single or double tab it crashes the software, doesn't seem like anyone else is having this issue
I tested my TT Pro and the app crashes on mine too.
I have the Fn button set how I like it but tried to change it to test and the "app stopped working" message appeared.
Good catch sinbad85, you're not the only one.
I had to modify my Anbee backpack also, so that I can leave it attached to the RC. Fits fine now. The tablet fits in the padded, zippered pouch on the back side along with my landing pad.
I do not have that problem with the std Tripltek (Android 8.1) tablet at Fly version 1.3.0
Thanks for checking. ?
My TT Pro is running Android 9.0 and I'm also using 1.3.0 FLY app.
I'm able to change the settings with another device with no problems and they stay set when using the TT.
I'm not sure if I want to mess around going back to an early Android build and taking a chance of bricking the TT. ?
I doubt you'd brick the tablet but I have gone back to previous versions of Fly before and I lost my previous flight history in the Android version of Fly, although I can still see all the previous flight history on my iPhone.
Yes, a bit pricey, but when I paid $800 for the tablet, wasn’t a big deal.
what I like is how it supports the controller extensions, antennas. It is very solid.
I just got mine and it is a very solid unit, despite its high price and installation challenges. But if your going to hang something as bulky as the Tripltek on something as small as the MA2 controller, it's a necessity. I'm happy with it.
Thanks, I just ordered one.
I got the STL file for one from Tripltek and had it printed but I don’t see any way it sits on the controller without it pushing the buttons at the bottom or being well secured at the bottom ..just seems to fall out …
how does yours fit from these guys?
You may already solve it. It is an issue with the display size.
go to Settings>Display ---- Change "Font size" value to Default, then change "Display size" value to Large.
It is also described on the Support page on TRIPLTEK website
Reactions: MA2 317
Thank you. ?
I'll change it when I get home.
Just changed mine .. I confess I find the support from the Tripltek folks to be excellent ..
Reactions: MA2 317
I'm still trying to find a good solution for an alientech mounted controller. The bottom is not very secure.
Sky fire aerial is one of the best tripltek mounting solutions available. Also can work with Alientech. Look there
It does not work with the alientech mount
My bad …. Good luck with your search … prob easier designing one to get it 3D printed …
Get yourself a Lanyard too.
You'll have a comfortable flight without the worries of dropping it.
I know the tablet is rugged but the remote is still fragile.
Here's my rig using my phone. It works the same with the mini4 and the homemade adapter I made like the one you purchased.
I just got the Tripltek for my MA2 and I need help figuring out what cable to use. I took two short cables from DJI to connect my Tripltek but I'm not comfortable with setup although it works fine. any suggestions? Thanks and HFTA!
Reactions: MA2 317
I've used the 2 cable approach since I got the TT .. No issues at all...
Reactions: MA2 317
I use the two cable system too.
The DJI stock cable and the short cable from Tripltek ( it's in the box).
I did try a cable from Thor but it didn't fit well and it was a pain to remove from the remote.
I haven't had any problems with the two cords.
gimfbsx
