Since purchasing my Mavic Air 2 I’ve looked for a better display to use when flying the drone. My iPhone 11 Pro worked OK but lacked real estate. I thought I had found a solution when I mounted my iPad Pro 11” (2018) on the controller. Unfortunately glare and the relatively dim (650 nits) display were less than effective. I invested in a Hoodman Sunshade (see first photo) but, even with the shade the display, when in full sunlight, was less than satisfactory. (Anyone looking for a new Hoodman Sunshade for an 11” iPad Pro?). Then I saw a post on the Tripltek Tablet. I purchased the 6GB “Standard Version” through Amazon (I could return it if I didn’t like it with Amazon). The Tablet arrived and I was impressed! It is housed in an impressive Military Grade case (the cases is 0.87” thick). The screen is bright, and I mean BRIGHT so no sunshade is required in full sunlight. Then I noticed the Tablet was running Android 9.0 not 8.1 per the spec sheet. I asked the company if there had been an upgrade and they said no, I had received the Pro model, thank you Amazon! I installed CPU-Z App and sure enough I have 9 Gigs of Ram and I’m running the faster processor. I loaded Android versions of DJI Fly, DJI GO4, B4UFLY, UAV Forecast, RMUS, Kittyhawk, Advisory, and Aviation Weather... They all run on the Tablet. The only “negative’ for me, running Android 9, it lacks a native screen recording capability, so I added AZ Screen Recorder App. I mounted the Tablet to the RC via a LifThor Baldur Mount. The mount positions the Tablet above the RC where it balances very well when flying (I also use a Liifthor neck strap with the mount). While flying and when doing numerous “ground tests“ with the System I have experienced zero issues or anomalies with the Tablet! The Tablet works well with the controller! Flying with this setup is nice... You have a screen you can see and read in full sunlight. The touch screen is responsive and the Tablet anti glare shield works well. I will say though, it does experience finger smudges, more so than the MYGOFLIGHT screen protector on the iPad! (BTW, the MYGOFLIGHT screen protector is hands down the BEST I’ve found for anti glare/smudge on your iPad or Tablet!). After using the Tripltek for 20+ flights and numerous ground tests I’m confident in its performance and frankly, I would highly recommend it for your drone application. One note, I’ve seen the chatter on SIM card compatibility with the Tablet. I can’t comment, I don’t use nor plan to use a SIM card in my Tablet.
