UFL to RP-SMA pigtails for controller mod - higher quality available?
The Bob
Just looking for better quality... maybe it is what it is? I did search the googs and found 2 sources.. MaxxUAV (just ordered a set today) and also SkyDronesUSA (replacing / see photo)
I was kind of hoping for a bit better quality than what I am seeing from these 2; especially for $20+ a set. Perhaps a bit better wire/shielding and termination to the U.fl and SMA connector ends. Had some signal issues and had to crack the controller open to investigate... found this failed SMA connection / pinched (my bad) but the connection was very poor to begin with; was working for the past year but apparently barely holding on... by a few wire strands.
67647
Maybe I am asking the wrong question but to any modders out there that modded the antenna... what did you use?
I also found these from ALIENTECH (much cheaper in cost... better quality?)
I just installed the Alientech Duo antenna which came with the Quick Release SMA. Definitely better quality then the others like 4hawks & ltelite. But the one you shown look different. Its look better quality than the others
BTW its costs US$10 for shipping to US
Reactions: The Bob
MaxxUAV Quality is pretty good so far. Much better signal now. I was also a bit more careful with the routing of the wires so I am sure that helps.
Reactions: Jeffm912
Noobie
