Update / What's the Connector type / or Name
billru
Texas
Looking for input on the camera signal cable connector on the top of gimbal mainboard pictured below, dose anyone any of (name, type, PN or where to find it). thanks
Looks like 2 connectors, is it at the top or bottom of the picture?
Without a pin count and size dimensions or part #, it's very difficult to pin down exactly.
You can search Mouser.com or digikey.com which carry electrical components but be aware there are literally several hundred thousand connectors on each site...
Cheers!
Its at the top, its the signal cable to the camera(40 pin) its 20 pins then a gap with another 20 pins after gapCable 1.PNG
On the top side of board the 40 pin that I am looking for supplies the camera and Roll motor, the one on bottom(16 pin)
goes to the Core board then on the other side of the Gimbal main board is another 16 pin which goes to the Yaw motor
For those that are interested I believed I put the component's together for the Mavic 2 Flexible Signal Cable
and Gimbal Motherboard socket
MIPI CSI-2
40 pin connector on each end of Signal Cable
DF56-40P-SHL
15 pin connector on cable to Gimbal flex cable
DF36A-15P-SHL
Gimbal Motherboard 40 pin socket
DF56C-40S-0.3V(51)
15 pin socket on flex cable
DF36A-15S-0.4V(51)
Reactions: mgracio
dvkhamtruocsinh
