I'm usually over on PhantomPilots, but considering a Mavic 2 Pro. Can I use my spare P4P controller/ With they link?
I'd stick to the P4P it has a better camera
No mavic 3 this year. And I would wait a year after it is release.
How much "better" of a camera do you want? The new Nikon D6 is 20MP because that is a sweet spot that balances ISO performance and resolution that pros like. I suppose they will do the standard camera marketing trick and jack the MPs.
If you want a quantum leap in cameras pick up an inspire.
Well I realize you’re a Canon shooter so you probably don’t know much about a D6 the body is $6000 so I don’t think it was for marketing and sales. Pretty sure it’s because that’s what the pros want.I've never used an Inspire, but I imagine the image quality is a bit better because of the lenses but the resolution is the same. The last 20 MP pro Canon body I bought was at least ten years ago. My current 5DSR's are 50 MP.
How much "better" of a camera do I want? Two factors. One is pixel count, I'd like to see closer to thirty. And then there is image quality, such as way better performance in low light conditions with less noise. Perhaps the ability to use higher ISO without losing quality. That would be a BIG one for drone cameras. I never use anything over ISO 100 because of noise and quality degradation. On my current Canons and Fujis, I can shoot up to 3200 with good results. Most drone snappers probably have no idea what I'm saying, but as a fine art printmaker this is important stuff.
The new Nikon D6 is 20MP because that is a sweet spot FOR MARKETING AND SALES. Affordability. There are no tricks. If I had 75 MP my images may not be better, but processing and printing and cropping would all be improved. Those that work at these levels understand.
They would rather have super good ISO performance and high FPS and superfast focusing. And they don’t fall into the mega pixel fallacy.
The real question is how much are you willing to pay for a 70 megapixel camera. My guess is it would add at least $2500 to the price of the drone.
Go take a look at phase 1 cameras For a quick price check.
That’s why I recommend the inspire it doesn’t come with the camera and there are several compatible cameras that can be put on it.
Maybe there’s not a 70 Mp yet But you have the best chance of putting a different camera on it.
Plus you can have interchangeable lenses.
Currently, there are 4 DJI prime lenses for the X7:Can you attach a third party lens to them?
You have to know that adding significant weight to the camera/lens makes it impossible to balance the gimbal and therefore renders the camera useless.Are there adapters for Canon, Nikon, Sony or Zeiss?
Those are lenses with Micro Four Thirds mounts, not for the DL mount the X7 is using.Several Olympus lenses are usable also. 12mm and 17mm.
Just now trying the Laowa 7.5
The Inspire 2 is significantly better- and not just because of the lenses. The APS-C sensor is much larger than the 1” in the P4P and Mavic. Larger photosites = improved SNR, high ISO performance and the freedom to shoot at smaller aperture before hitting the diffraction limit.I've never used an Inspire, but I imagine the image quality is a bit better because of the lenses but the resolution is the same. The last 20 MP pro Canon body I bought was at least ten years ago. My current 5DSR's are 50 MP.
The 20mp canon you are taking about was probably the 1Ds Mk3, I still have 2 from when they were released in 2008 and they work perfectly. Built like tanks.
If you are a pro shooter with the revenue to justify it Inspire 2 or larger platform that can fly your DSLR’s would seem the obvious choice.
I’m pretty sure the DJI X7 won’t take canon lenses.Thanks, W.T.Birds. I owned a 1DsIII for a long time as my main camera. Loved every minute of it.
I never thought that full frame intended lenses from Canon or Nikon would work on an Inspire. Was just curious. How about the Fuji X mount? I have a couple of XPro2's and a bunch of lenses. Great quality. Handy size.
