Video lagging
LACR
Philippines
I fly m2z. Usually on 1080_ 30. Using 64 sd card 95 write speed 633x lexar
When i fly i have lots of video lag . I stop recording...no lag... start can get lag.
Is there something i should be looking at to stop lagging. Very annoying.
is Your SD card U3? ... and in the open slot for a second card with that one chosen in preferences after you power up?
Make sure your card is not almost full. I noticed mine had some lag when the card was getting full and capturing video in d-log or h265. If that’s not it, you might try a different SD card.
think he means internal 8g memory... seems to me that OP as A slow memory card a lot of fake cards about ?
I have tried diff cards. Formatted. Cleared caches. Different settings from 4k to 1080.
I use epson bt 300 glasses. Turned off bluetooth. Off the wifi.
Still lag just when i hit record.
Anyone use write cards of 200 plus in 1000x or more?
OK LACR Try using internal 8g Memory if you still have problems with lag than its got to be hardware issue
Have you tried turning off the video caching to your device.
Yes i did but dont know exactly what i did but it stopped lagging . I did change some settings for the camera and changed sd card from 64 to 32
Reactions: JThalheimer
dtcexpress1
