Has anyone used a visibility wrap on their Mini and what would you recommend, as these are so small they are difficult to keep in sight even in the best light. Plus my old eyes aren't the best either. Thanks ,, KC
I have just ordered a sticker kit from ebay for mine to see if it helps. It was under 10 dollars from memory.Has anyone used a visibility wrap on their Mini and what would you recommend, as these are so small they are difficult to keep in sight even in the best light. Plus my old eyes aren't the best either. Thanks ,, KC
Yeah, I thinkin maybe on the arms and legs and underside. Also a small strobe, between the bottom sensors and the aircraft status indicator, if I can find one that will fitI have just ordered a sticker kit from ebay for mine to see if it helps. It was under 10 dollars from memory.
nice ideaI made my own from a piece of reflective sheet. It works reasonably when the drone is low enough to have landscape behind it. When high, and the dronen is a silhouette it doesn't help. I crashed the drone in a tree once and had it not been for the bits of yellow catching my camera flash I'd never have found it!View attachment 107014
