Vision Sensor Error
M1N1M3
Hi Guys,
I'm new to this, just got hold of my Mavic yesterday and did a trial run, unfortunately, battery went low and it knocked against the window and had a dent on the front next to the sensors, its say vision sensor error and on the controller it says check app, i tried restarting it as some of guys advised but it didnt go away.
I can still use it and fly around, but the error is still there, is there anything i could do or should i send back to DJI authorised shop?
Hi Guys,
Just to be sure....did you remove the protective stickers on the sensors??
Reactions: SeaComms
Have you tried calibrating the front sensors with DJI Assistant?
Reactions: Pablo
Yes do this before considering sending it back etc.
I did it recently, and it worked well. It's actually pretty fun too :pThumbswayup
I also had the "Vision Sensor Error" on my Mavic Pro. I was pretty frustrated, but after a few hours I found the "Assistant" Mac desktop app and re-downloaded the latest firmware and did the sensor/camera calibrations using the computer camera and it worked!
Got the green "Ready to Go" and the error went away.
Mavic – Specs, FAQ, Tutorials and Downloads
Definitely try this.
Hi Guys,
SOLUTION
SOLUTION
Hi Guys,
cbooth
