Hello,
I just bought a used Mavic Pro,
and everything seems to work, except the forward vision Sensors.
After starting the drone, it says, that there is an error for the forward left and right vision Sensors.
I opened the mavic pro, and checked the connection of the Sensors and everything looks as it should be.
When i try to calibrate it with the DJI Assistant Software, i can't see a square, which i have to match with the other square on the screen.
Also both of the Screens of the Sensor Status are greyed out.
I tried changing the Screenresolution and disconnecting my second Monitor, but nothing worked for me.
Is there anything I can do, to get this Problem solved?
I thought of buying another Sensor board, but maybe there is another solution to that.
Any Help is appreciated!
