Waypoint task library
Nboost
Can you add more than one task to the library? After I add a task to the library & then try to add another it overwrites the first one. Is this just the way it is?
not done it in a while, but I never done anything special, I had 5 or more missions saved until updates wiped them out, twice now, cant be bothered to do any more just for an update to delete them all again.
Firmware updates DELETE YOUR ENTIRE TASK LIBRARY?
This is bad. Have you confirmed this happens to everyone (not just a quirk with yours)? Have you confirmed with DJI that this is normal?
Chris
It's called complacency. We're used to it, even though it's possible for them to design a system where firmware updates do not change any of your user configuration.
But these are not just configuration settings -- they are mission parameters that take some time to create. They should NEVER clobber your task library.
Another reason to just use LITCHI.
Chris
Mooseknuckles
