Waypoints 2.0 camera always turned to the right not straight front
Tasos GR
Greece
Hi all,
I've tried to flight a simple mission with DJI Waypoints 2.0 with my M2 Zoom.
Destination 1 to 2, no POI just a direct line.
Both setting Flight Direction to Route.
According the manual "Flight Direction: By default, this setting will be set to Route and the drone will point in the direction it's traveling".
But anytime I tried the camera always turned to the right not straight front.
Below attached a photo to explain better the situation.
Did I do anything wrong or missed something?
Please for your help.
Thank you
The camera will point in the last direction it was pointed at unless you set it straight or set a poi
There was no other direction only 1 to 2 straight in front.
The camera begins the mission looks in front and after some secont little by little turns right.
here are some photos that maybe help
when you set a mission , you not only have to set the drone position but also the camera angle, if you record a point it stores both
I set the angle to 45o for up and down but there is no settings for left to right.. it supposed to follow the route by default (or the POI if you set one.. in my case no POI at all)
i will try it tomorrow, during my exercise, im guessing that the camera was moved on point 2
I think I find the problem.... in settings "All Waypoint Direction" was set to "Custom Route" and not "Route"
I will try again tomorrow
Thank you so much for your help anyway ?
Reactions: pelagic_one
in litchi waypoints , the camera points at the same direction as it was at take off unless it told to look elsewhere, I hope this helps, and I will try dji go later
  • Love
Reactions: Tasos GR
tflys78
