Welp, this sucks
Halcyon
U.S.
I was planning to fly my MA2 above my house to film the SpaceX Crew Dragon launch this happening in about an hour. However, when I checked for NOTAMs on 1800wxbrief.com, I discovered that my house is about 1 1/3 miles inside the temporary national defense no fly zone. ?
Here it is, just for laughs. The good parts are in red:
FL..AIRSPACE CAPE CANAVERAL, FL..TEMPORARY FLIGHT RESTRICTIONS. MAY 27, 2020 LOCAL. THIS NOTAM REPLACES NOTAM 0/1729 DUE TO CHANGE REGULATORY AUTHORITY AND ADDITION OF COORDINATION PHONE NUMBER IN PARAGRAPH A. PURSUANT TO 49 USC 40103(B)(3), THE FEDERAL AVIATION ADMINISTRATION (FAA) CLASSIFIES THE AIRSPACE DEFINED IN THIS NOTAM AS 'NATIONAL DEFENSE AIRSPACE'. PILOTS WHO DO NOT ADHERE TO THE FOLLOWING PROCEDURES MAY BE INTERCEPTED, DETAINED AND INTERVIEWED BY LAW ENFORCEMENT/SECURITY PERSONNEL. ANY OF THE FOLLOWING ADDITIONAL ACTIONS MAY ALSO BE TAKEN AGAINST A PILOT WHO DOES NOT COMPLY WITH THE REQUIREMENTS OR ANY SPECIAL INSTRUCTIONS OR PROCEDURES ANNOUNCED IN THIS NOTAM: A) THE FAA MAY TAKE ADMINISTRATIVE ACTION, INCLUDING IMPOSING CIVIL PENALTIES AND THE SUSPENSION OR REVOCATION OF AIRMEN CERTIFICATES; OR B) THE UNITED STATES GOVERNMENT MAY PURSUE CRIMINAL CHARGES, INCLUDING CHARGES UNDER TITLE 49 OF THE UNITED STATES CODE, SECTION 46307; OR C) THE UNITED STATES GOVERNMENT MAY USE DEADLY FORCE AGAINST THE AIRBORNE AIRCRAFT, IF IT IS DETERMINED THAT THE AIRCRAFT POSES AN IMMINENT SECURITY THREAT. PURSUANT TO TITLE 14, CODE OF FEDERAL REGULATIONS, SECTIONS 91.141 AND 99.7 SPECIAL SECURITY INSTRUCTIONS, ALL AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN AN AREA DEFINED AS 40 NM RADIUS OF 283700N/0803700W (MLB009030.6) SFC-17999FT MSL EFFECTIVE 2005271630 UTC (1230 LOCAL 05/27/20) UNTIL 2005272130 UTC (1730 LOCAL 05/27/20). WITHIN AN AREA DEFINED AS 30 NM RADIUS OF 283700N/0803700W (MLB009030.6) SFC-17999FT MSL; EXCLUDING AN AREA DEFINED AS 285157N/0810725W (ORL030022.3) TO 285157N/0810200W (ORL039025) TO 284155N/0810200W (ORL060018.5) TO 284155N/0811116W (ORL040012.1) TO THE POINT OF ORIGIN. SFC-2000FT MSL EFFECTIVE 2005271630 UTC (1230 LOCAL 05/27/20) UNTIL 2005272130 UTC (1730 LOCAL 05/27/20). EXCEPT AS SPECIFIED BELOW AND/OR UNLESS AUTHORIZED BY ATC IN CONSULTATION WITH THE AIR TRAFFIC SECURITY COORDINATOR VIA THE DOMESTIC EVENTS NETWORK (DEN): A. ALL AIRCRAFT OPERATIONS WITHIN A 30 NMR AREA LISTED ABOVE, KNOWN AS THE INNER CORE, ARE PROHIBITED EXCEPT FOR: MILITARY AIRCRAFT IN SUPPORT OF LAUNCH ACTIVITIES, AIRCRAFT ASSOCIATED WITH CAPE CANAVERAL OPERATIONS, RESCUE/RECOVERY AIRCRAFT, APPROVED LAW ENFORCEMENT, APPROVED AIR AMBULANCE FLIGHTS, APPROVED FIRE FIGHTING OPERATIONS AND FLIGHTS APPROVED THROUGH THE U.S. DEPARTMENT OF STATE. ALSO, REGULARLY SCHEDULED COMMERCIAL PASSENGER AND ALL-CARGO CARRIERS OPERATING UNDER ONE OF THE FOLLOWING TSA-APPROVED STANDARD SECURITY PROGRAMS/PROCEDURES: AIRCRAFT OPERATOR STANDARD SECURITY PROGRAM (AOSSP), FULL ALL-CARGO AIRCRAFT OPERATOR STANDARD SECURITY PROGRAM (FACAOSSP), MODEL SECURITY PROGRAM (MSP), TWELVE FIVE STANDARD SECURITY PROGRAM (TFSSP) ALL CARGO, OR ALL-CARGO INTERNATIONAL SECURITY PROCEDURE (ACISP) AND ARE ARRIVING INTO AND/OR DEPARTING FROM 14 CFR PART 139 AIRPORTS. ALL EMERGENCY/LIFE SAVING FLIGHT (MEDICAL/LAW ENFORCEMENT/FIREFIGHTING) OPERATIONS MUST COORDINATE WITH ATC PRIOR TO THEIR DEPARTURE AT 407-852-7553 TO AVOID POTENTIAL DELAYS. B. FOR OPERATIONS WITHIN THE AIRSPACE BETWEEN THE 30 NMR AND 40 NMR AREA(S) LISTED ABOVE, KNOWN AS THE OUTER RING: 1. ALL AIRCRAFT OPERATING WITHIN THE OUTER RING(S) LISTED ABOVE ARE LIMITED TO AIRCRAFT ARRIVING OR DEPARTING LOCAL AIRFIELDS, AND WORKLOAD PERMITTING, ATC MAY AUTHORIZE TRANSIT OPERATIONS. AIRCRAFT MAY NOT LOITER. ALL AIRCRAFT MUST BE ON AN ACTIVE IFR OR FILED VFR FLIGHT PLAN WITH A DISCRETE CODE ASSIGNED BY AN AIR TRAFFIC CONTROL (ATC) FACILITY. AIRCRAFT MUST BE SQUAWKING THE DISCRETE CODE PRIOR TO DEPARTURE AND AT ALL TIMES WHILE IN THE TFR AND MUST REMAIN IN TWO-WAY RADIO COMMUNICATIONS WITH ATC. 2. ALL VFR AIRCRAFT OPERATIONS WITHIN THE 30 TO 40 NM RADIUS TFR ARE RESTRICTED TO AN INDICATED AIRSPEED OF 180 KNOTS OR LESS, IF CAPABLE. IF UNABLE, THE PILOT MUST CONTACT THE APPROPRIATE ATC FACILITY AND ADVISE THEM OF THE AIRCRAFT'S OPERATIONAL LIMITATIONS. C. THE FOLLOWING OPERATIONS ARE NOT AUTHORIZED WITHIN THIS TFR: FLIGHT TRAINING, PRACTICE INSTRUMENT APPROACHES, AEROBATIC FLIGHT, GLIDER OPERATIONS, SEAPLANE OPERATIONS, PARACHUTE OPERATIONS, ULTRALIGHT, HANG GLIDING, BALLOON OPERATIONS, AGRICULTURE/CROP DUSTING, ANIMAL POPULATION CONTROL FLIGHT OPERATIONS, BANNER TOWING OPERATIONS, SIGHTSEEING OPERATIONS, MAINTENANCE TEST FLIGHTS, MODEL AIRCRAFT OPERATIONS, MODEL ROCKETRY, UNMANNED AIRCRAFT SYSTEMS (UAS), AND UTILITY AND PIPELINE SURVEY OPERATIONS. D. UAS OPERATORS WHO DO NOT COMPLY WITH APPLICABLE AIRSPACE RESTRICTIONS ARE WARNED THAT PURSUANT TO 10 U.S.C. SECTION 130I AND 6 U.S.C. SECTION 124N, THE DEPARTMENT OF DEFENSE (DOD), THE DEPARTMENT OF HOMELAND SECURITY (DHS) OR THE DEPARTMENT OF JUSTICE (DOJ) MAY TAKE SECURITY ACTION THAT RESULTS IN THE INTERFERENCE, DISRUPTION, SEIZURE, DAMAGING, OR DESTRUCTION OF UNMANNED AIRCRAFT DEEMED TO POSE A CREDIBLE SAFETY OR SECURITY THREAT TO PROTECTED PERSONNEL, FACILITIES, OR ASSETS. E. FAA RECOMMENDS THAT ALL AIRCRAFT OPERATORS CHECK NOTAMS FREQUENTLY FOR POSSIBLE CHANGES TO THIS TFR PRIOR TO OPERATIONS WITHIN THIS REGION. F. THE 1ST RANGE OPERATION SQUADRON, /45 SPACE WING/, TELEPHONE 321-853-5936, IS IN CHARGE OF THE OPERATION. 202005271630-202005272130
Kinda be a long shot.
Reactions: Simone L
What would you expect.They havn’t had a manned launch
in 9 years.
Preferably not closing off 22,661cubic miles of airspace. After all, this rocket is supposed to go up, not sideways (well, actually, it does sort of go sideways).
Reactions: Drgnfli
The launch has been scrubbed for today. Maybe the no fly radius will be reduced on Saturday since Trump & Pence will presumably not be there.
Reactions: brett8883
They would do that just for the president being in town... On top of that you have a manned space flight.
Reactions: jagraphics
According to B4UFLY, the 40nm radius no fly zone is a Presidential no fly zone. I guess 30nm is the norm for launches, so hopefully I can fly on Saturday.
Looks like they canceled the launch because of weather, I would try and drive the mile and a half outside and see if you can get some footage when they reschedule it. That would be some fantastic footage. by the way if you are ever down in the Fort Meyers area we have a retail store and would love for you to stop in!
Reactions: Halcyon
I don't think a drone, at the distance you'd be permitted to fly, would be a good choice of camera platforms given the generally wide field of view making the rocket just a dot in the frame. At that distance you need a telephoto lens to see things closer/bigger. So, it would be a waste of time/effort unless viewing a glowing dot is your thing...
Brian
A new TFR has been posted for Saturday. The area is a lot smaller as of right now.
@Halcyon maybe Saturday you will get to fly.
Reactions: Halcyon
.....OR C) THE UNITED STATES GOVERNMENT MAY USE DEADLY FORCE AGAINST THE AIRBORNE AIRCRAFT, IF IT IS DETERMINED THAT THE AIRCRAFT POSES AN IMMINENT SECURITY THREAT.
. D. UAS OPERATORS WHO DO NOT COMPLY WITH APPLICABLE AIRSPACE RESTRICTIONS ARE WARNED THAT PURSUANT TO 10 U.S.C. SECTION 130I AND 6 U.S.C. SECTION 124N, THE DEPARTMENT OF DEFENSE (DOD), THE DEPARTMENT OF HOMELAND SECURITY (DHS) OR THE DEPARTMENT OF JUSTICE (DOJ) MAY TAKE SECURITY ACTION THAT RESULTS IN THE INTERFERENCE, DISRUPTION, SEIZURE, DAMAGING, OR DESTRUCTION OF UNMANNED AIRCRAFT DEEMED TO POSE A CREDIBLE SAFETY OR SECURITY THREAT TO PROTECTED PERSONNEL, FACILITIES, OR ASSETS. .
That seems reasonable to me.
the first section is the standard one for *aircraft* that pose and imminent security threat.
the second section is for small drones which basically says we use signal jammers and your drone is going to fall out of the sky. Again very reasonable.
Life sucks. Get over it.
Just be glad you don’t live in Palm Beach County when Trump is in town pretty much shuts it all down.
I live just passed the TFR the Stuart airport gets real busy at that time.
Reactions: Halcyon
I considered it, but the weather is hazy and overcast, so it's probably not worth the effort.
I that case maybe they'll scrub the launch and wait until better weather.
Then you could get it on video outside the restricted zone.
I'm going to try. Unfortunately, the atmosphere is almost always hazy this time of year.
Good for you. You read the NOTAM. Smart flying.
Reactions: sdold
I'm a retired air traffic control operations supervisor and many years ago I actually worked that area of airspace, and over the course of my career I can say that TFR violations are not taken lightly. We have had the military scramble fighters on many, many occasions on aircraft that violated, or were heading into, the TFR. I am aware of two circumstances where the aircraft were escorted to the airport and were met by gentlemen in black SUV's. As far as the TFR's for rocket launches chances are it will stay the same size even without any Presidential movements in the area. The airspace is sterile not only at the launch site but for several hundred miles downrange, with the exception of aircraft that are patrolling the area. On a normal day when air traffic is at normal operating levels this creates a bottleneck on the west side of the launch area, and is even worse if there's weather. All traffic that would normally be traversing off the coast is now required to be routed inland. TFR's for general Presidential movements are very strict too. It literally shuts down the airport and everything around it. Okay, so can the Feds/military actually know if you're flying a drone within the TFR? Now I cannot confirm nor deny anything, but I would stay on the ground, especially if there's Presidential movement associated with that TFR.
al3597
