What are the rules for flying near a small, untowered, small aircraft, municipal airport with no circle or altitude squares mapped around it.
StevenBrodsky
miami
I haven't done my research about flying near small airports. Maps only show the airport, but it has no circle or altitude restriction squares near it on those maps. All I have done so far, is use LAANC to get cleared to fly across the blue landing and take off strip on the map every 2 days or so. I was flying across the zone so often at one point, that I had DJI clear the Geo zone for me for one year.
Reactions: Cafguy
Check the FAA UAS Map
Reactions: Ancient Aviator
NORTH PALM BEACH COUNTY GENERAL AVIATION AIRPORT. It has a diagram, but no circle or altitude restriction squares.
From the Folks at ALOFT
Reactions: dart106 and NoBozos
I just looked. The airport location is named, but all it shows is a road going there and nothing else whatsoever. It doesn't even show the airports layout.
Then you should be fine to fly
Reactions: TonyPHX
It’s still good information but I thought B4UFly had been replaced with Aloft Air Aware as the FAA recommended app. Please correct me if I’m wrong as I don’t want to spread bad information.
As long as you are in class G airspace you just have to avoid other aircraft and ”fly with caution” Which is the only restriction I get before flying. I do this frequently at an airport nearby and avoid flying when I see other aircraft in the area. If aircraft come into the area, I land and don’t resume flying until the area is aircraft free. I am also a private pilot and have an aircraft based here. The only exception you may have, is if there are local ordinances prohibiting or regulating drone usage.
Looking at the chart below, North Palm Beach County General Aviation Airport (F45) appears to be non-towered, however lies right on a dashed magenta line indicating, per the FAA Aeronautical Chart User Guide, Class E Airspace down to the surface, and thus would be considered within controlled airspace. Kind of splitting hairs here...because without a magnified view to see where the magenta dashed line actually bisects the airport it's difficult to determine...however I'd error to the side of conservatism, and consider it "Surface Type E2" Class E Airspace controlled to the surface, and thus requiring permission to fly from the FAA. But I've been wrong before!!
Reactions: Cafguy and RangerEd
I erred in my original reply and corrected it. I meant to say class G airspace, not E which is controlled. Sorry about that
Thanks Everyone for responding. If anyone else feels the need to chime in feel free to do so.
calos69
