Ok so can you explain it why it moves right then left I know dumb question right ?
That is the app that we are all talking about it has the yellow H the travels across the screen on top is the battery depletes, you don’t get that with the fly appHow do you get the go4app
Different aircraft use different apps, you can't use the GO4 app with an aircraft that needs FLY.How do you get the go4app
I’ll have to find that menu. Thanks.If you have a smart controller when you turn it on it eventually shows you the menu of drones that it will run
Battery Level Indicator
This shows you how much power your battery has left. The line gets shorter as the battery power is depleted. The first dot on the left is when the drone will automatically land due to low power. The second dot is when the app will try to activate RTH unless you stop it. The yellow H represent your home point and moves along the line to show how much power you will need to get your drone back home.The yellow return to home indicator is dynamic and it will change based on how far your drone is at the time from the home point.
It bases the estimate on your current draw- if you're flying into the wind and then hover, it will move to the right. When your draw increases it will move left again. Overall, it will move left.Ok so can you explain it why it moves right then left I know dumb question right ?
The go 4 app is used with drones like the Mavic two pro and drones prior to that one
Concerning the different apps for flying, wondering if someone might have a matrix that shows which apps can be used with which drones, and if those apps can be used on the SC or need to be on phone or tablet.
