Wifi booster mavic mini
208driver
Holland
Ola,
would these work for the mini CE ?
edit: i have the 4hawks SR installed
i understand it would have to set it to 2,4ghz.....not sure if the video signal is also 2,4.
was thinking about buying 2.
Ola,
You'd have to modify the remote controller quite significantly to get this to work, it is not guaranteed to improve range
Might be better to go with simpler non-amplified solution first to try
Reactions: DjPegg
tflys78
