Wrong dates saved into videos and photos metadata
krige
Tallinn, Estonia
Using exiftool I can see the metadata of video and photo files taken with my Mavic mini.
The problem is that the photo dates are 1 hour ahead of the time they were actually taken, while the videos are 2 hour behind.
Here's an example of output of exiftool on a photo file (actual taken time was 2020:06:27 20:35:44):
Code:
ExifTool Version Number         : 12.01
File Name                       : DJI_0001.JPG
Directory                       : .
File Size                       : 4.3 MB
File Modification Date/Time     : 2020:06:27 21:35:50+03:00
File Access Date/Time           : 2020:06:28 11:43:19+03:00
File Creation Date/Time         : 2020:06:28 11:15:51+03:00
File Permissions                : rw-rw-rw-
File Type                       : JPEG
File Type Extension             : jpg
MIME Type                       : image/jpeg
Exif Byte Order                 : Little-endian (Intel, II)
Image Description               : DCIM\100MEDIA\DJI_0001.JPG
Camera Model Name               : FC7203
Orientation                     : Horizontal (normal)
X Resolution                    : 72
Y Resolution                    : 72
Resolution Unit                 : inches
Software                        : v02.51.0008
Modify Date                     : 2020:06:27 21:35:49
Y Cb Cr Positioning             : Centered
Exposure Time                   : 1/120
F Number                        : 2.8
Exposure Program                : Program AE
ISO                             : 100
Exif Version                    : 0230
Date/Time Original              : 2020:06:27 21:35:44
Create Date                     : 2020:06:27 21:35:44
Components Configuration        : -, Cr, Cb, Y
Compressed Bits Per Pixel       : 3.774029333
Shutter Speed Value             : 1/120
Aperture Value                  : 2.8
Exposure Compensation           : 0
Max Aperture Value              : 2.8
Subject Distance                : 0 m
Metering Mode                   : Center-weighted average
Light Source                    : Daylight
Flash                           : No flash function
Focal Length                    : 4.5 mm
Warning                         : [minor] Possibly incorrect maker notes offsets (fix by 1783?)
Make                            : DJI
Speed X                         : +0.00
Speed Y                         : +0.00
Speed Z                         : +0.00
Pitch                           : -0.20
Yaw                             : +59.10
Roll                            : +0.20
Camera Pitch                    : -11.80
Camera Yaw                      : +1.20
Camera Roll                     : +0.00
Flashpix Version                : 0010
Color Space                     : sRGB
Exif Image Width                : 4000
Exif Image Height               : 2250
Interoperability Index          : R98 - DCF basic file (sRGB)
Interoperability Version        : 0100
Exposure Index                  : undef
File Source                     : Digital Camera
Scene Type                      : Directly photographed
Custom Rendered                 : Normal
Exposure Mode                   : Auto
White Balance                   : Auto
Digital Zoom Ratio              : undef
Focal Length In 35mm Format     : 24 mm
Scene Capture Type              : Standard
Gain Control                    : None
Contrast                        : Normal
Saturation                      : Normal
Sharpness                       : Normal
Subject Distance Range          : Unknown
Serial Number                   : 1SFLH3F0AB0MJ7
GPS Version ID                  : 2.3.0.0
GPS Latitude Ref                : North
GPS Longitude Ref               : East
GPS Altitude Ref                : Above Sea Level
XP Comment                      : Type=N, Mode=P, DE=None
XP Keywords                     : v02.51.0008;0.0.1;v1.0.0
Compression                     : JPEG (old-style)
Thumbnail Offset                : 18432
Thumbnail Length                : 10564
About                           : DJI Meta Data
Format                          : image/jpg
Absolute Altitude               : +33.89
Relative Altitude               : +19.60
Gimbal Roll Degree              : +0.00
Gimbal Yaw Degree               : +1.20
Gimbal Pitch Degree             : -11.80
Flight Roll Degree              : +0.20
Flight Yaw Degree               : +59.10
Flight Pitch Degree             : -0.20
Cam Reverse                     : 0
Gimbal Reverse                  : 0
Version                         : 7.0
Has Settings                    : False
Has Crop                        : False
Already Applied                 : False
MPF Version                     : 0010
Number Of Images                : 2
MP Image Flags                  : Dependent child image
MP Image Format                 : JPEG
MP Image Type                   : Large Thumbnail (VGA equivalent)
MP Image Length                 : 270502
MP Image Start                  : 4283115
Dependent Image 1 Entry Number  : 0
Dependent Image 2 Entry Number  : 0
Image UID List                  : (Binary data 66 bytes, use -b option to extract)
Total Frames                    : 1
Image Width                     : 4000
Image Height                    : 2250
Encoding Process                : Baseline DCT, Huffman coding
Bits Per Sample                 : 8
Color Components                : 3
Y Cb Cr Sub Sampling            : YCbCr4:2:2 (2 1)
Aperture                        : 2.8
Image Size                      : 4000x2250
Megapixels                      : 9.0
Scale Factor To 35 mm Equivalent: 5.3
Shutter Speed                   : 1/120
Thumbnail Image                 : (Binary data 10564 bytes, use -b option to extract)
GPS Altitude                    : 33.8 m Above Sea Level
GPS Latitude                    : 59 deg 28' 22.17" N
GPS Longitude                   : 24 deg 43' 24.48" E
Preview Image                   : (Binary data 270502 bytes, use -b option to extract)
Circle Of Confusion             : 0.006 mm
Field Of View                   : 73.7 deg
Focal Length                    : 4.5 mm (35 mm equivalent: 24.0 mm)
GPS Position                    : 59 deg 28' 22.17" N, 24 deg 43' 24.48" E
Hyperfocal Distance             : 1.28 m
Light Value                     : 9.9
Here's an example of output of exiftool on a video file (actual taken time was 2020:06:27 20:39:02):
Code:
File Name                       : DJI_0003.mp4
Directory                       : .
File Size                       : 62 MB
File Modification Date/Time     : 2020:06:27 21:39:18+03:00
File Access Date/Time           : 2020:06:28 11:51:14+03:00
File Type                       : MP4
File Type Extension             : mp4
MIME Type                       : video/mp4
Major Brand                     : MP4 Base w/ AVC ext [ISO 14496-12:2005]
Minor Version                   : 2014.2.0
Compatible Brands               : avc1, isom
Media Data Size                 : 64769618
Media Data Offset               : 44
Movie Header Version            : 0
Create Date                     : 2020:06:27 19:39:02
Modify Date                     : 2020:06:27 19:39:02
Time Scale                      : 30000
Duration                        : 14.78 s
Preferred Rate                  : 1
Preferred Volume                : 100.00%
Preview Time                    : 0 s
Preview Duration                : 0 s
Poster Time                     : 0 s
Selection Time                  : 0 s
Selection Duration              : 0 s
Current Time                    : 0 s
Next Track ID                   : 4
GPS Coordinates (err)           : 59 deg 28' 24.24" N, 24 deg 43' 22.44" E
Speed X (err)                   : +0.00
Speed Y (err)                   : +0.00
Speed Z (err)                   : +0.00
Pitch (err)                     : +2.10
Yaw (err)                       : +161.10
Roll (err)                      : -0.90
Camera Pitch (err)              : +0.00
Camera Yaw (err)                : +1.50
Camera Roll (err)               : +0.00
Comment                         : DE=None,SN=1SFLH3F0AB0MJ7, Type=Normal, HQ=Normal, Mode=P
Category                        : v02.51.0008, 0.0.1, v1.0.0
Model                           : FC7203
User Data mux (fr)              :
User Data mux                   : ..
Track Header Version            : 0
Track Create Date               : 2020:06:27 19:39:02
Track Modify Date               : 2020:06:27 19:39:02
Track ID                        : 1
Track Duration                  : 14.78 s
Track Layer                     : 0
Track Volume                    : 0.00%
Image Width                     : 1920
Image Height                    : 1080
Graphics Mode                   : srcCopy
Op Color                        : 0 0 0
Compressor ID                   : avc1
Source Image Width              : 1920
Source Image Height             : 1080
X Resolution                    : 72
Y Resolution                    : 72
Compressor Name                 : AVC encoder
Bit Depth                       : 24
Video Frame Rate                : 29.97
Meta Format                     : priv
Warning                         : [minor] The ExtractEmbedded option may find more tags in the media data
Matrix Structure                : 1 0 0 0 1 0 0 0 1
Media Header Version            : 0
Media Create Date               : 2020:06:27 19:39:02
Media Modify Date               : 2020:06:27 19:39:02
Media Time Scale                : 30000
Media Duration                  : 15.00 s
Handler Class                   : Media Handler
Handler Type                    : Text
Handler Description             : .DJI.Subtitle
Gen Media Version               : 0
Gen Flags                       : 0 0 0
Gen Graphics Mode               : ditherCopy
Gen Op Color                    : 32768 32768 32768
Gen Balance                     : 0
Other Format                    : text
GPS Coordinates                 : 59 deg 28' 24.24" N, 24 deg 43' 22.44" E
Speed X                         : +0.00
Speed Y                         : +0.00
Speed Z                         : +0.00
Pitch                           : +2.10
Yaw                             : +161.10
Roll                            : -0.90
Camera Pitch                    : +0.00
Camera Yaw                      : +1.50
Camera Roll                     : +0.00
Image Size                      : 1920x1080
Megapixels                      : 2.1
Avg Bitrate                     : 35.1 Mbps
GPS Latitude                    : 59 deg 28' 24.24" N
GPS Longitude                   : 24 deg 43' 22.44" E
Rotation                        : 0
GPS Position                    : 59 deg 28' 24.24" N, 24 deg 43' 22.44" E
Does anyone know how I can fix this problem?
Underbool
