But they do improve live feed stability & distance if they are made with the correct dimensions for the wavelength you use (either 2,4GHz or 5,8GHz).
Bought them for my
MA1 just because they were cheap & I was curious ...
In the same location (open farmland), the same height (120m/400ft) & in FCC mode with 2,4GHz ...
I reached 2,6km without Yagi's ... the live feed was out there really laggy & not usable anymore & the flight ended with a disconnect and RTH.
With Yagi's I reached a tad longer than 4km, actually turned around manually as the battery didn't allow a longer flight ... the live feed was perfect & without any lag.
The Yagi's is highly directional though ... so it's more important to point your RC correctly. They will not improve going out of unobstructed LOS ... they are equal sensitive to that as using the RC without them ... so going behind things will as usual generate a disconnect. So flying in a sub-urban environment will usually mean that you have obstacles like houses & trees on a distance from you that rises the free horizon level by approx 7 degrees ... with some trigonometric calculations you end up with a distance of approx 1000m up on 120m height before the AC disappears behind a house roof.
Have also noted that with Yagi's you more easily punch through WiFi disturbance ... have a smaller industrial area close by with some taxi cab headquarters which probably have some equipment that creates a virtual wall of disturbance which I can't fly through with the plain RC in 5.8GHz ... with Yagi's attached I fly over with just a smaller hiccup in the live feed.
