Hi, from France
Actualy shooting with Air 2S, since 1 month.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Mapā€¦" Check it out and you might find some new flying friends.
Since you live in France, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Adviceā€¦
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its ownā€¦). On the Drone, open the front legs, then open the back legs, then remove the Gimbal Cover.
The Gimbal is the most delicate item on the Drone and banging or bumping can damage it. I also fastened a short "Remove Before Flight" ribbon to the cover so it's more noticeable and I do not forget to remove itā€¦
Turn on the drone and watch it come to "life." Watching the Gimbal go through its self-check is almost like watching a kitten or puppy opening its eyes for the first timeā€¦
Place the drone down (preferably on a Landing Pad) while it finishes its self-test (collecting satellites, etcā€¦).
If you go out in a rush and race thru your start up and take off before the drone has finished it prep, it may update its Home Point over that pond or that old tree you are flying over and in your excitement, you'll fly the drone long past it Low Battery point and when it engages Return to Home and lands in the pond or in a tree; it will be all on youā€¦
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
After you read the Manual, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary momentā€¦"
Happy Droningā€¦
Welcome to the forum! :)
Welcome to the forum.
Lots of great info and members here !!!
Reactions: MA2 317 and GFields
Welcome to the forum šŸ‘
Welcome to the forum from Chicago the Windy City.
FLY SAFE & FLY SMART
dominicus15
