Hi
Hello from the Crossroads America stooge75.
Can’t wait for my drone to arrive tomorrow
What ya' gettin'?
Whatever it is, it's gonna be fun, :)
Read the manual a few times, watch videos, and ask questions.
Welcome to the Forum. :cool:
Welcome to the forum! :)
I saw your other postings that your drone is the Mini 3 pro so I included the Link to all of DJI's downloads including the User manual at the end of this posting…
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from Chicago the Windy City.
FLY SAFE & FLY SMART.
I Love Scotland.
Reactions: LoudThunder
Pocki
