beanbubba
- Joined
- May 7, 2017
- Messages
- 1,845
- Reactions
- 1,405
Actually, I wanted to ask you about amplifiers. The Sunhams 3W amp is only putting out 170mW. Do we need preamps to get the full 3W? It's basically 4 times the power of the controller, giving more than double the range when coupled with higher gain antenna, but still a tiny fraction of advertised power. I wonder if one could put the Sunhams amps in series to get full power. The first would act as the preamp. I suppose it might be to strong in preamp role, exceeding input maximum on the the second amp.
Cybernate, please help get me up to speed on this topic.
This is the first I have heard the the sunhams effective output is 170mW, how did you conclude this? I do not have one to test, but I just ordered a pair from amazon right now with delivery Friday and I will verify this coming weekend.
I am currently using 250mW amps from Hyperlink that easily handle the 6 mile run I just completed. If I had line of sight, these could just about handle 10 miles. The 3 watt amp's are complete overkill on paper, but I am intrigued why you suspect that the sunhams are only 170mW.
These are some examples of the amp's that I use in my day job:
WiFi Booster | WiFi Amplifier | WiFi Extender | L-com
Regarding your question about pre-amp's, this is not something that is practiced in this discipline. All of these devices have a receiver sensitivity and can easily be damaged if you exceed their rated input values. There are devices available to match any situation you could ever need in RF link budget planning and using pre-amp's is not something that is practiced because it adds unnecessary attenuation that can be easily avoided. I can help you with the RF math on how all this works and the parts required to accomplish the desired goal.
