NanoSync Antenna for DJI Mavic Coming Soon
Website that sells everything plan on spending about $400 REXUAV | HOME
Rite already checking it out. How will it help through some foliage about 1 mile away. I'm trying to keep track of a couple deer herds around the house.
They don't seem to mind the bird at all just move in slow
Have you tried NOT using the booster on the right antenna (receiving antenna)? Is there any noticeable difference?
For some reason circular works better on the downlink side already unboosted. Boosting it's better but not that pronounced as the tx side. I like boosting both for the heck of symmetry and slight improvement.
Reactions: poet and Natedoggz
Thanks! That will save me a few bucks :)
Have you seen the booster im using currently? It's dual and same price as 1 of the golden ones. Bit bigger but i like it..
Older pic...replaced the last thin coax by rg58 as well. As said, like symmetry.
Looks cool! But not something I would want to bring for travel :)
I think I will just modified my P4P and keep the Mavic stock as it's the one I take for travelling.
Reactions: djhoodrich
One more question did you buy the mount that mounts to the controller the transmitter or did you make that and if you did where can I buy it
Djhoodrich,
I think you might want to direct the questions to Maclak instead of to me
this thing outputs 4 Watts I think I'm going to order this
The indicated Watts are by no means an indication on how strong the output signal is. The 3W mini sunhans has the same, if not, slightly less performance than the 1W booster im using. I have both.
The main mount is the Nanosync mount. I have modified the antenna plate to fit this.
The amp mount is attached to the main one by some old mini bearings, 2 strips meccano and 1 plastic thingy used in construction (spacer). This is way better than any 3d printed stuff. I will mod it slightly to fit a dual 3w sunhans setup too (much more compact but twice the price) for testing the nanosync boosted soon ( OR @JakeMaxxUAV amazes me with his solution and i ll be using those;)).
The amp still needs battery power but this i attach to the back of my Moverio trackpad.
Reactions: JakeMaxxUAV
Sounds like a wise plan. More or equal compact compared to stock is impossible.
Still my setup has a too big antenna and too big amp. I can make both way smaller but the current setup fits my bag so im not in a hurry to minimize.
I have used many antennas for the Mavic Pro but to date nothing beats the boosted circular polarized antennas, I have tried them boosted and unboosted..... having them unboosted was a little better than stock. for distance, penetration and high-volume of Wi-Fi interference you need to boost them...
Kevin
Reactions: Natedoggz
Thanks guys! You saved me from doing "unnecessary" upgrades on the Mavic.
I wrote unnecessary with quotes because I may still want to do it just for fun if I can find a relatively cheap second hand RC locally :)
Reactions: jhansen
Kit is on it's way!! :)
norman157
