Welcome from the Hampton Roads area of Virginia, USA. I am a
Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the
Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby."
Below is the link to all of the downloads offered by DJI for the SE. You will also find the 47-page SE User's Manual, in case your Mini did not come with one. The User Manuals are published in different languages.
At DJI Download Center, Learn aboutDJI Mini SE
www.dji.com
Happy Droning
