Chris4koi
Welcome to the Forum from Sunny Somerset, UK
Thanks for all the info, definitely going to take it slow and get in plenty of practice, do the drills etc. maintaining orientation I think going to be the hardest part for me!Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby."
Below is the link to all of the downloads offered by DJI for the SE. You will also find the 47-page SE User's Manual, in case your Mini did not come with one. The User Manuals are published in different languages.
Happy Droning
