SD Card Or Hard Drive
Status
Not open for further replies.
Dingdong
Tasmania
When you insert the micro card into the drone.....will it automatically record to the card or will it continue to record the the onboard drive as in previous flights without card?
Not sure which aircraft you're flying but with the Mavic Air it's a setting that continues your previous selecting from your last flight
You need to go to preferences on the drone while it is running and designate the card you inserted as the place to save. This will remain until you actively change it regardless of time passage or number of startups of the drone.
Reactions: old man mavic
Status
Piason
