Ah - now surely that should have the Mavic Pilot's badge on the front?I’ve even got the hat View attachment 57436
No you are a remote pilot and you are flying an aircraft. If you think any other way then you are not being safe and not being serious about what you do. We have had this discussion a thousand times, just search the forum.
I strongly disagree with you on being pilots. I know it is a term that people want to use to sound impressive, but calling oneself a pilot does not make you one. As you say, "we have had this discussion many times", still just an operator of a little quad that goes up and always comes down.Welcome to Mavicpilots.com. If you ever need advice or repair questions, feel free to reach out to the forum.
Best regards and good luck,
Rob
Well my friend, we are just going to have to agree to disagree. It isn't about sounding impressive at all. There is a lot of work, money and responsibility that goes into being a commercial drone pilot, and even a recreational pilot for that matter. It is way more than just flipping a few switches and moving some sticks. No a drone doesn't have the same flight characteristics as a fixed wing aircraft, and no we don't have 1 5 or 400 passengers behind us that we have to be responsible for. But, there is a lot of responsibility in flying a drone. There is a lot of property and sometimes people on the ground around you that you have to be accountable for. You are flying in airspace that does have manned aircraft around you. You have to do a lot of pre flight planning, some that has to be done days, weeks and sometimes in the case of certain waivers, months before flights. If you are doing things the right way, you are doing just about as much or more pre flight planning as the average recreational pilot that is making a short hop around their home airfield. (and yes I can say that with personal knowledge, I have flown before, I have been through flight training) You have to know how to read and understand air charts. You need to know what the airspace is you are flying in and near and know when you need to obtain permission to fly in that airspace. You need to be able to check NOTAMS and understand what you are reading when you are in certain types of airspace. You need to understand weather and how different types of wind, humidity, air density and temperature affect the flight characteristics of your aircraft. (yes all of that affects your little drone) Even though you say it just goes up and comes down, that isn't actually the case unless you think landing in trees, on top of people's houses, in the middle of a freeway or flying away to God knows where is an acceptable way to come back down. The FAA says that if you are over .55 lbs then you are flying an aircraft. AND, last time I looked my Part 107 Airman's Certificate says Remote PILOT, not remote operator or toy quad flyer. (yep just looked again, hasn't changed a bit). So you call yourself whatever you want to call yourself, and I will call myself what the FAA states I am on my Airman's Certificate. It isn't about a title or sounding impressive.I strongly disagree with you on being pilots. I know it is a term that people want to use to sound impressive, but calling oneself a pilot does not make you one. As you say, "we have had this discussion many times", still just an operator of a little quad that goes up and always comes down.
Howdy from Wyoming welcome to the community, plenty of fine folk and excellent information here.We are drone operators.
I remotely control a UAV. That makes me the PIC (pilot in command, or person inWe are drone operators.
You are correct the other person is just another "nit picker". Enough of this P.C. garbage.Well my friend, we are just going to have to agree to disagree. It isn't about sounding impressive at all. There is a lot of work, money and responsibility that goes into being a commercial drone pilot, and even a recreational pilot for that matter. It is way more than just flipping a few switches and moving some sticks. No a drone doesn't have the same flight characteristics as a fixed wing aircraft, and no we don't have 1 5 or 400 passengers behind us that we have to be responsible for. But, there is a lot of responsibility in flying a drone. There is a lot of property and sometimes people on the ground around you that you have to be accountable for. You are flying in airspace that does have manned aircraft around you. You have to do a lot of pre flight planning, some that has to be done days, weeks and sometimes in the case of certain waivers, months before flights. If you are doing things the right way, you are doing just about as much or more pre flight planning as the average recreational pilot that is making a short hop around their home airfield. (and yes I can say that with personal knowledge, I have flown before, I have been through flight training) You have to know how to read and understand air charts. You need to know what the airspace is you are flying in and near and know when you need to obtain permission to fly in that airspace. You need to be able to check NOTAMS and understand what you are reading when you are in certain types of airspace. You need to understand weather and how different types of wind, humidity, air density and temperature affect the flight characteristics of your aircraft. (yes all of that affects your little drone) Even though you say it just goes up and comes down, that isn't actually the case unless you think landing in trees, on top of people's houses, in the middle of a freeway or flying away to God knows where is an acceptable way to come back down. The FAA says that if you are over .55 lbs then you are flying an aircraft. AND, last time I looked my Part 107 Airman's Certificate says Remote PILOT, not remote operator or toy quad flyer. (yep just looked again, hasn't changed a bit). So you call yourself whatever you want to call yourself, and I will call myself what the FAA states I am on my Airman's Certificate. It isn't about a title or sounding impressive.
I believe they are referring to an aircraft that the pilot actually sits in, not a model type aircraft that flies from a remote control. There-in lies the difference. An actual pilot would always have been deemed the person who controls the craft from within the craft, not outside it, as in drone flying.Oxford English Dictionary ... Pilot
"A person who operates the flying controls of an aircraft. "
Oxford English Dictionary ... Aircraft
"An aeroplane, helicopter, or other machine capable of flight. "
Looks like we can be Pilots or Drone Operators ... take your pick.
I'm Irish and an Celtic WarriOr. A Celtic Warrier would mean you are Celtic and and a member of a Hindu Caste. Interesting mix for sure.I remotely control a UAV. That makes me the PIC (pilot in command, or person in
charge). And as far as a 'DRONE' goes, imo, a drone is a military vehicle that shoots
stinger missles, and other terrifying stuff at enemies as well as civillians (men, women, and children also, and is controlled/flown by someone 300' below ground in a bunker, somewhere near Piney Flats, Tenn...
And BTW, please stop 'filming' . I don't know anyone who still uses film. I record data files, which consist of photos and/or videos.
End of rant..........
pls sign me: Havin' fun w/ my MA....................K
