2.7K with 60 FPS
mkjo
Hello,
the datasheet of the Mini2 says that possible video modes are
2,7K: 2720×1530 with 24/25/30/48/50/60 fps
(DJI Mini 2 - Specifications - DJI)
I can select only 24, 25 and 30 FPS.
Is there anybody out there who made recordings with more than 60 FPS?
Thanks, so far.
It was added in the latest firmware update, you probably haven't updated.
Thanks for the answer!
As soon as you ask, you find the answer...
I'll doublecheck the version numbers. I used the Fly version from the play store, which is at 1.2.1 at the moment. For 2.7K I need the 1.2.2 or later, which is not in the play store. So I'll changed to the sideloaded version.
The firmware in the mini was already the updated, I was able to use 2.7K out of the box. So the 1.2.1 version just misses the selection in the camera menu...
I am looking forward to smooth videos with 60 Hz, even with ND filters the 60Hz are very useful.
Together with the RAW feature, and the pano mode, for my use-cases the Mini 2 is now the true replacement for my old Mavic (1) Pro.
Reactions: Kilrah
NIKLM
