2.4GHz band travels long range better.
5.8GHz band is quieter, in that a hell of a lot less devices use 5.8GHz compared to 2.4 GHz.
So it depends on the environment really.
Yep 5.8 allows faster data transfer hence less lag and more pq.While that is really the expected norm, I wonder how it works out when we select auto, and dual band vs single band....
With my Air1 I usually set to 5.8GHz and found it works to a similar distance but get less lag and more picture quality.
With Air 2 I find it always goes to 5.8G if I set it to auto dual band.
No doubt. I imagine in CE regions 5.8G will really not go far even if uninterrupted, so the switching to 2.4G will occur near the end of 5.8G usefulness.Yep 5.8 allows faster data transfer hence less lag and more pq.
I imagine the auto mode is constantly checking for congestion, and switches when needed to keep you on the quietest band.
Yep but regardless of power 2.4 wont be much cop in a heavily congested (urban) area.
Yeah I think this is the logical approach...and one less thing to worry about.I leave mine in auto and let the air 2 do the work. I am sure it can do a far better job than me anyway!
And for someone like me.......that’s very important!Yeah I think this is the logical approach...and one less thing to worry about.
Are you assuming occusync uses the same encoding scheme as standard wifi? I suspect there is no basis to your claim here.Yep 5.8 allows faster data transfer hence less lag and more pq.
You suspect wrong then.Are you assuming occusync uses the same encoding scheme as standard wifi? I suspect there is no basis to your claim here.
Why do you say 5ghz will have higher data rate with occusync?You suspect wrong then.
Encoding schemes dont come in to it.
I was speaking generally, I dont have time to read the reports you've posted, but it's a surprise that DJI are not utilising this.May I know where you got this piece of info ? From the following test reports for MA2 submitted to FCC by DJI. The channel bandwidth and modulation are the same for both bands. It's just that the number of channels available for the 5.8 GHz is higher :
5.8 GHz : https://fccid.io/SS3-MA2UE1N1911/Test-Report/Test-Report-4682145.pdf
2.4 GHz : https://fccid.io/SS3-MA2UE1N1911/Test-Report/Test-Report-4682115.pdf
Base on this info, I have reason to believe that the maximum data rate is independing of the frequency band.
Utilising what?I was speaking generally, I dont have time to read the reports you've posted, but it's a surprise that DJI are not utilising this.
Correct me if im wrong, but generally speaking, surely at higher frequencies more data can be carried due to higher bandwidth?I am not sure what you meant by "generally" and "utilizing this". What does "this" refer to ? some technical principles ? standards or something ?
Take cellular network as an example. Many frequency bands are used, from 600 MHz all the way to over 30 GHz. As long as the technology ( GSM, WCDMA, LTE, 5G, etc ) is the same , the maximum data rate does not depend on the frequency band.
