Abrupt signal loss
yo_eddie
Germany
Recently I experienced an abrupt loss of the connection between controller and Mini 2 drone. The signal went straight from 100% signal strength down to zero. This happened two times during one flight, one time the drone was only 20 meters in front of me.
Flightlog
Any ideas how this could happen? There was a ferry line a kilometres away, but ship radars should use very different frequencies.
@yo_eddie ,did you at any point fly behind the ferry
was it actually the control signal you lost or just the visual return signal from the drone to the RC could you still control the drone when this happened a complete signal loss between the RC and the drone would normally instigate a RTH
Reactions: EyesWideShut
The screen showed the dreaded black & white picture and the drone initiated RTH both times. When the connection was established again, I canceled RTH and landed manually.
When I check the log at Airdata, the signal for up- and downlink drops from 100 to 0 and then back to 100 both times (see notifications at Minute 01:19 and 06:11).
Also the log states weak GPS signal at the same time.
@yo_eddie ,its possible that you have a faulty ,drone and or RC ,contact DJI support ,and if you have care refresh ,go for a replacement ,the symptoms you have are not normal
Reactions: yo_eddie
SK farming
