Hi, I'm after some advice please. I have added a short video below to make clear what I am wanting to acheive (no music).
I am considering setting up a flight similar to below, except with the camera facing straight down and following the river with very little yawing of the drone so that all the 'S' curves (example at about 15secs) 'ripple' down the frame as the drone moves forward (I hope this is understandable), probably from about the same height.
At the end of the clip, to the upper left of centre you can see some grey farm buildings, and the total flight would be from the beginning of this clip to about 2000m past those buildings.
I could not do this in one flight without the use of Waypoints, as the total distance is about 4700m (as the crow flies); the flight below is about 1200m. The flight would not pass over any buildings or people and would cross one minor road.
Firstly, and most importantly, would Go4 be able to cope with this and give good results or would I be better purchasing Litchi?
Secondly, should I plan 2 flights instead, one to the minor road (about 2800m) from start and then move to that road and start a second mission?
I would be using the Mavic 2 Pro in 'P' mode, so would the battery cope with one single flight of this distance and have enough juice to safely return?
I am fairly new to this so would appreciate any advice.
