Advise on active track settings
William Ball
Snowy Western NY
Hi All,
I did a short active track test this morning in 6 degree weather, yes 6 degrees F. But the wind had not picked up yet. Anyway I digress. I did a test of active track and noticed the quad is quite jumpy and the video shows the "jerkyness" of the quad. Should I adjust the braking to smooth out this start and stop motion? It seems like the quad would "catch up" to me and then brake, start moving again and brake again. I'd like it to follow more smoothly. Thanks for any help you can give me. I'll fiddle around with it when I thaw out. Right now the temp is 30F and the wind is 20 MPH.
-Bill
Cold may play a factor but when was your last IMU calibration? The built in accelerometer and angular rate sensor in the IMU may be out of cal. Give it a shot.
cbooth
