The FAA has no altitude limitation for flying over private property.
That is not a lower limit, not at this time and it does not specifically apply to airspace over private property.Though they’d really like you to stay under 400 feet everywhere in the US. This is soon to be an actual rule.
I like to practice my s and figure 8 turns at a low altitude about 75 feet and it is over the neighbor hood. just want to know if that is legal.Don't want to get in trouble if for some reason some one gets mad. If they do I'll fly some where else.
I down loaded AirMap but kind of complicated. is B4UFly better??
Interesting that B4UFly is not on FAA’s list of apps approved to grant LAANC clearance for flying in NFZs. The first time through AirMap you have to enter your info. After that, each time just open the app and apply for time once in your location and enter how long you want to fly. LAANC approval comes almost immediately. See the reference below about half way down the page...again, note the absence of B4UFly, which is several years old and being reworked currently by Kittyhawk. Also note that DJI is not currently approved, but is on the list.
Your approval will have any info about height restrictions etc.UAS Data Exchange (LAANC)
www.faa.gov
Why does AIRMap grant clearance in 2 other categories now?LAANC only applies to Part 107 flights, so it's not going to be of much use to the OP flying recreationally.
www.faa.gov
Depending on the airport and how close you are to it, the airspace could be restricted to less than 400 ft. You should find your location here: ArcGIS Web Application
