It's really hard to analyse flight data when users have updated to app version 1.2.2 or later because DJI changed their encryption.Hello, my mavic mini flew away.
Thanks for your feedback.It's really hard to analyse flight data when users have updated to app version 1.2.2 or later because DJI changed their encryption.
That means that we can't see much of the data to tell what happened.
But with the little that Airdata does show it's pretty clear that your drone blew away in a wind that was too strong for it to fly against.
When you allow your drone to be blown away, it's not right to say that it flew away.
Because it had plenty of battery left when signal was lost, and the wind was gusty and variable it's not possible to give an accurate idea of where it will have come down.
But a rough calculation would suggest it 2.3 miles or more to the east of where signal was lost.
Right, but the warning is/was popping up even with winds <20 kph. I get your point, but it doesn't reflect the actual weather conditions of the flight in question. In any case, I have flown with stronger winds or gusts (even in way higher altitudes >2000 m) without an issue."Athough the telemetry showed several strong wind warnings........"
I think that might have had something to do with it!
The term flyaway suggests that the drone itself flew away but analysis of flight data from hundreds of flight incidents shows that drones don't just fly away at all.What would be a typical "fly away" case for you?
I accept the fact that you have flown at much higher altitudes and when you quote (>2000m) I hope you mean dstance and not height. (Possible height restriction hack).Right, but the warning is/was popping up even with winds <20 kph. I get your point, but it doesn't reflect the actual weather conditions of the flight in question. In any case, I have flown with stronger winds or gusts (even in way higher altitudes >2000 m) without an issue.
Good point, but why do you think DJI offers Flyaway coverage with the mavic mini 2? They define flyaway as "situations aircraft goes missing during flight", and that really makes me wonder what's going on...The term flyaway suggests that the drone itself flew away but analysis of flight data from hundreds of flight incidents shows that drones don't just fly away at all.
When people say flyaway they usually mean : I lost my drone but don't know why.
"stop the rotors wasn't possible" Does this mean that the mini (original) does Not have the emergency shutdown like the Mini 2?Thanks for your feedback.
Yet, I'm not sure I agree with your statement that "When you allow your drone to be blown away, it's not right to say that it flew away." I understand that RTH wasn't an option, but both sticks were dead and any attempt to fly it back, reduce altitude, land it, stop the rotors etc wasn't possible. I didn't have much options anyways. What would be a typical "fly away" case for you?
I mean 2000 m asl, not agl, where air is quite thinner and the aircraft struggles even with the slightest wind gust. Due to it's low mass/weight, VLOS is my preferred mode for mavic mini. I have flown however BVLOS with my good ole phantom 3 many times, but only where conditions permit it.I accept the fact that you have flown at much higher altitudes and when you quote (>2000m) I hope you mean dstance and not height. (Possible height restriction hack).
Do you not believe in VLOS at all?
It has, but since the sticks were dead, the option wasn't available"stop the rotors wasn't possible" Does this mean that the mini (original) does Not have the emergency shutdown like the Mini 2?
Sorry, I haven't heard the term, 'sticks dead' before, so I don't/didn't understand the term.It has, but since the sticks were dead, the option wasn't available
I was very disappointed to see DJI reinforcing the false idea that their drones are likely to fly away.Good point, but why do you think DJI offers Flyaway coverage with the mavic mini 2? They define flyaway as "situations aircraft goes missing during flight", and that really makes me wonder what's going on...
It's hard to put together what happened with almost no description of your incident and only the Airdata report to use to reconstruct it.I understand that RTH wasn't an option, but both sticks were dead and any attempt to fly it back, reduce altitude, land it, stop the rotors etc wasn't possible. I didn't have much options anyways. What would be a typical "fly away" case for you?
The poor GPS message came at 2 seconds before the drone had acquired GPS,There are also messages telling about poor GPS performance and later "no signal".
There was nothing to suggest any problem with the compass and the drone wasn't in atti mode at all for the flight.This usually indicates that there might be a problem with compass calibration, too. At least the Mini has fallen back into Atti mode and then it is quite easy to blow it away.
Yep ... the wind was way over the top for a tiny Mini unfortunately... this was not so much more than a BlowAway.I am afraid the wind was really strong. The craft was in RTH mode ( flycStateRaw = 15 ) throughout the second half of the flight. The pitch angle was aroudn -25 degree ( ie, nose down ) on average and yet the craft was travelling backward at a speed of 15 mile/hour on average. Adding the air speed of 18 mile/hr at that pitch angle , the wind speed was 15 + 18 = 33 mile per hour which was way too strong for the little thing.
There has been a recent case in which the Mini issued false strong wind warning due to IMU problems but in your case this was unlikely to be the reason because there was a lot of "Not enough force / ESC errors" warnings as well so the motors was really working hard to counter the wind but in vain.
