- Joined
- Mar 6, 2017
- Messages
- 654
- Reactions
- 238
- Age
- 54
You get this after you perform an update with one battery, then put another one in and attempt to fly. That is because when a mavic updates, it updates rc, ac and currently inserted battery. You have to go through this process with every battery you own. If you only have one battery, try running the update again using the Dji assistantHey guys, just got a "Battery status error" message on the app. Never had this before. I shut the app down and opened it up again and the error had disappeared?
Anything to be concerned about?
Thoughts please guys.
I've just taken the battery back out and put it back in again and restarted everything and the error has now disappeared.You get this after you perform an update with one battery, then put another one in and attempt to fly. That is because when a mavic updates, it updates rc, ac and currently inserted battery. You have to go through this process with every battery you own. If you only have one battery, try running the update again using the Dji assistant
It was not the procedure I meant, but if that did it then if was a one-off error and everything is fineI've just taken the battery back out and put it back in again and restarted everything and the error has now disappeared.
Is that now fully fixed? Is that the procedure you meant for me to do?
Thanks mate, I appreciate your help [emoji3]It was not the procedure I meant, but if that did it then if was a one-off error and everything is fine
That makes sense, mine had also been auto discharged, that will be the problem. Thanks mate.I have gotten it after a battery has auto discharged for storage. Recharge and all was good.
Same here once you do a full recharge it's all good to goI have gotten it after a battery has auto discharged for storage. Recharge and all was good.
