Just got my Mavic P and I want to buy a I Pad Mini4, my question is do I need phone service to it or just WiFi?
just wifi and gps if you want to use follow me,ectJust got my Mavic P and I want to buy a I Pad Mini4, my question is do I need phone service to it or just WiFi?
ur using apple so im not exactly sure but gps isnt needed,just wifiSo with out data no maps correct?
So if I get the one with GMS that will down load maps and I don't need data plan?
Thanks for the info.@Jgels, if you want to use the Follow Me flight mode or be able to reset the home point to your current location after taking off (useful in a case where you move away from the original home point), you'll need to use a mobile device that contains a GPS receiver. For Apple devices, that means you need to buy a cellular model. You don't have to activate the cellular service in order to use the GPS data. If you don't need to use those two features, then save some money and get a Wi-Fi only iPad. iPads are more expensive when you purchase a cellular model and do not activate the cellular service.
For the maps, you can download and cache them in DJI GO like this in a location where you can connect to Wi-Fi before you head out to fly. Once cached, the maps will be available when DJI GO is not able to access the Internet. If your mobile device has a cellular connection, then you could of course just download the maps in real-time as you're flying.
