Beginning, which app do I download for the older Mavic Pro Platium
You need the DJI Go or the DJI Go 4 app
which app. do I download for the Mavic Pro Platinum?
I believe that's the dji go app. I would recommend downloading it from the DJI website and NOT the app store.
Oh and welcome to the forum.
You might also want to log onto out sister site… they specialize on the Phaontom…
However, as a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine!
camposbrito
