Best camera settings for Mavic 2 Pro (guide)
So, i was thinking to ask in a separate thread, but, may be it will be better to place it here.
it is probably not a simple topic, and it has several parts to it.
here is a link to a test i did today:
at 1min into that clip the yaw rotation begins. now, in the re-processed youtube clip it is barely visible, but, the yaw rotation is not smooth there. M2P was in the P mode and very slowly rotating, but, when i look at the clip - reprocessed one or an original one, in the DaVinci Resolve or in the VLC - i can see how screen 'jerks' a bit when gimbal moves left-right trying to keep up with the drone rotation. i have a feel the settings of the gimbal or mechanics are not smoothing up that yaw rotation enough.
again, in the raw footage it is quite visible. it is also visible after initial processing in the Resolve to apply color correction.
but, in the youtube it is smoothed up - so, it means they do something else to stabilize those 'jerks' in between frames. how do they do it?
so, that is essentially a question - first, is there anything available in the free version of the davinci resolve to smooth up that flow? as when i tried to add something like that into the fusion step it said it is only working in the paid version
second part of the question - is there anything else available in the camera or gimbal settings to smooth up specifically yaw rotation, to slow down speed of gimbal`s reaction to the change of the yaw angle. not sure how to explain it better. i hope it should not be something new in this topic, but i could not find any specific instructions on how to improve or tune it.
so, i figured out how to share it - here is a google drive link to the converted clip, shortened just to the rotation part, 450mb. any ideas what can be done there to fix the problem?
Untitled.mov
PS. for the Resolve software i found this article, trying to play with what it says to do in the stabilizer window, but, results so far are not very impressive.
How to Stabilize Video Footage in DaVinci Resolve 12.5
faridudinmuhammad
