Best Frequency for Forest Flying
photosinflight
raleigh nc
I’m going on a camping trip this week and before leaving, I’m trying to plan out my flights a bit.
Part of my planning is trying to figure out whether I should be flying using dual-band frequency, or specifying between 2.4/5.8.
The reason I ask is because my flight will essentially be following a river with many trees obstructing the transmission from the RC controller to my Mavic 3 (and yes, that also means I will not be maintaining VLOS during these flights.)
I’ve read that the 2.4 frequency is better for long distance flights and assumed it might be the similar for my situation. Can anyone confirm this? TIA!
PS - Please don’t bother commenting about how I should be maintaining VLOS. You’ll just be wasting your time.🙏🏻
Radio waves can't pass through water and trees are full of water.
Your control signal won't be affected by a branch or two but if you get enough foliage and timber between the controller and the drone, the signal won't get through.
What you are suggesting sounds like you want to break the laws of physics.
But I guess telling you that is wasting my time?
Reactions: Cafguy
The best Is the 2.4....It wont help you a bit for being around trees and stuff tho. See post above.
You are also planning a flight above a "Forested Area". while not a national forest, Special rules Apply there and over ANY forested area.
For N.C. flight over is allowed unless you are anywhere near the DuPont State Recreational Forest, In that case your flight cannot happen.
Check carefully the laws regarding Flying a Drone over these areas in your state and adjust your flight attitude Accordingly.
In other words:::: Flying Beyond VLOS AND Starting a Forest fire would NOT be good for you. and would be a very expensive venture.
Mike-Drone
