Having problems with Pictures and photo transfer through Bluetooth will transfer to a sansung phone ok but will not go to an iPhone using a smart controller.
This is a good tutorial, Aldryn uses iOS in this video.Having problems with Pictures and photo transfer through Bluetooth will transfer to a sansung phone ok but will not go to an iPhone using a smart controller.
Thats What going on shows that is connect to the smart controller on iPhone & iPad and on the smart controller shows iPhone and ipadGo share uses the WiFi connection between your iPhone and SC...
if Bluetooth doesn’t connect (but shows that it’s paired) I can help you out...
Paired
Shows connected on both SC ,iphone & ipad but SC shows not sent when you sendingYes ... that’s what mine said and was driving me nuts ... here’s what you do... have your phone opened to Bluetooth screen .. on the SC , open to see GO screen .. tap circle with 4 squares on bottom right... go to settings and tap MORE... tap tethering ... turn on Bluetooth tethering.... than tap connect (on your iPhone) where you see your SC ... it should connect ..
