Borrowed quite a bit from this post: Emergency procedure
Flight checklist (Appendix A) - https://www.tc.gc.ca/en/services/aviation/publications/tp-15263.html
Question is specifically around:
The small RPAS pilot operating within visual line of sight must be able to:
I have modified/updated for more relevancy for my Mavic Mini/Air and am looking for comments on meeting the requirements for the Flight Review, the idea is to have this as a reference during the review:
Loss of Control/Flyaway
- Describe emergency procedures that apply to your sRPAS;
- Describe the lost-link procedures that apply to your sRPAS;
- Describe the procedures to follow in the event of a fly-away, including who to contact.
- Step to aid in Prevention:
- Set Return to Home (RTH) altitude
- Make sure RTH has been set
- Will get a prompt on the App (need 4 bars on GPS)
- Green spot will appear on map
- Verify no compass interference
- If event occurs
- Pilot
- If control is not restored, activate Return to Home (RTH). Check whether the mode is functional and/or if the control of the drone has been regained
- Turn off and on the controller and try to recover control of the drone
- If safe to do so, attempt to power off the motors
- If drone flyaway continues, note drone battery life, height, speed and heading
- Inform the police via 911 and/or Air Traffic Control (ATC)
- Maintain Visual Line of Sight (VLOS) with the drone for as long as possible
- Crew
- Clear/Warn any individuals in vicinity if possible
- Retain VLOS with the drone for as long as possible
- Await instruction from the pilot
- Pilot
- Check if your crew has visual of the drone
- Consider increasing altitude to clear known obstacles
- Focus on the video stream and navigate drone home
- Use map/radar to manually fly drone home
- Engage Home lock and use pitch stick backwards to fly drone home
- Yaw drone so that "nose" is pointing in flight direction to help guide it home.
- Engage RTH
- Focus on visual contact and track the drone to determine its location
- If possible, get others to help as spotters
- Try to realign antennas to regain contact
- Try relocating RC to regain contact (move to higher ground or closer to Drone)
- Wait for RTH to engage and drone to return
- If Drone does not return, use "Find my drone" function in Go app to try to locate it
- If drone does not return use "Find my drone" function in Go app to try to locate it
- Keep visual contact with drone and fly home manually
- Focus on the video stream and navigate ac home
- Use map/radar to manually fly ac home
- If Drone is "lost" in known location, make sure it is safe to attempt recovery.
- Consider getting assistance if location is deemed inaccessible or unsafe.
- Have a small medical kit available
- Know where the nearest medical facility is located
Incident | Pilot Response | Crew Response | Follow Up |
Pilot Incapacitation Pilot is unwell or unresponsive |
Public Entering Flight Area A person who is not under the control of the pilot enters the flight location. |
