CE version and FCC version
TDZHDTV
East Riding of Yorkshire, Great Britain
So my first shake down test flight managed a 1200m @70m from home point before signal became a real issue (and for the record I fly VLOS normally). Aircraft Transmission was set to Auto, channel 149 5.8GHz.
I’ve realised today I can manually select a single digit channel and the frequency changes to 2.4GHz.
I Understand the 2.4 and 5.8GHz from an interference prospect if your in a urban area, can somebody please explain how this fits with CE and FCC version discussions.
the FCC version only has 5.8GHz the CE version has both 2 .4 and 5 .8
Reactions: Marc101 and TDZHDTV
As above be the FCC version only has 5.8ghz but more power. The version has 2.4ghz and 5.8ghz. the lower power means you'll get better range on 2.4ghz with the CE model
Oh and it's not a small power difference. The FCC version has 1w / 1000mw at 5.8ghz. the CE version has about 0.025w / 25mw.
The 2.4ghz on the CE version is 80mw so 4x the power of the 5.8ghz in CE. Simple maths means that you should get double the range with 2.4ghz than you would with 5.8ghz but radio travels differently. The same power at 5.8ghz should cover less range than at 2.4ghz
sscott062
