Commercial Drone Licensing in USA
Utah
Team,
I am a 25 year pilot and hold multiple FAA aeronautical ratings.
Part 107 is taken directly from the PPL test which leads me to believe that I do not have to obtain an additional sub-rating to operate a drone commercially.
Your thoughts?
I also read this from Skyward.com: " Every drone pilot who flies commercially must either have a traditional pilot's license or pass the part 107 knowledge test and receive an operating certificate." This is the only place I have come across this verbiage so far.
Thanks for any help and guidance you can provide.
DB
Unmanned Aircraft Systems
Existing Pilots – What to Expect
Eligibility:
  • Must hold a pilot certificate issued under 14 CFR part 61
  • Must have completed a flight review within the previous 24 months
Remote Pilot Certificate Requirements
  • Must be easily accessible by the remote pilot during all UAS operations
  • Valid for 2 years – certificate holders must pass either a recurrent online training course OR recurrent knowledge test every two years
Application Process:
  1. Complete the online training course "Part 107 small Unmanned Aircraft Systems (sUAS) ALC-451" available on the FAA FAASTeam website – initial training course areas include:
    1. Applicable regulations relating to small unmanned aircraft system rating privileges, limitations, and flight operation
    2. Effects of weather on small unmanned aircraft performance
    3. Small unmanned aircraft loading and performance
    4. Emergency procedures
    5. Crew resource management
    6. Determining the performance of small unmanned aircraft
    7. Maintenance and preflight inspection procedures
  2. Complete FAA Form 8710-13 (FAA Airman Certificate and/or Rating Application for a remote pilot certificate)
    1. Online or by paper (see instructions in previous section)
  3. Validate applicant identity
    1. Contact a FSDO, an FAA-designated pilot examiner (DPE), an airman certification representative (ACR), or an FAA-certificated flight instructor (CFI) to make an appointment.
    2. Present the completed FAA Form 8710-13 along with the online course completion certificate or knowledge test report (as applicable) and proof of a current flight review.
    3. The completed FAA Form 8710-13 application will be signed by the applicant after the FSDO, DPE, ACR, or CFI examines the applicant's photo identification and verifies the applicant's identity.
      1. The identification presented must include a photograph of the applicant, the applicant's signature, and the applicant's actual residential address (if different from the mailing address). This information may be presented in more than one form of identification.
      2. Acceptable methods of identification include, but are not limited to U.S. drivers' licenses, government identification cards, passports, and military identification cards (see AC 61-65 Certification: Pilots and Flight and Ground Instructors)
    4. The FAA representative will then sign the application.
  4. An appropriate FSDO representative, a DPE, or an ACR will issue the applicant a temporary airman certificate (a CFI is not authorized to issue a temporary certificate; they can process applications for applicants who do not want a temporary certificate).
  5. A permanent remote pilot certificate will be sent via mail once all other FAA-internal processing is complete.
Reactions: TheGameColonel
Eligibility:
Thank you very much!!
DB
LeoleoLeo
