I had asssumed they were both magnetic, but could be wrong.Is the gimbal heading based on true North or Magnetic North? I've never used that App before.
0.4 degrees here!You could use one of the web based true north calculators and see what the difference is. If it is about 30 degrees difference where you flew your drone likely that is the answer. If its not close it is probably some other reason.
