Looks just like the parts I replaced. My camera literally broke a piece off of the vibration plate, which is made from metal. Those fragile looking metallic thread wires that carry video are actually pretty tough. The ribbon cable is easily damaged. I wish they sold those rubber pieces separately. I ruined two of my new ones, but was able to transfer two of the old ones to the new plate. Hooking them up is harder than unhooking them. Somebody needs to make a special tool for this. They're very stretchy, but will cut through on any sharp edge in an instant.
Mine came with them already installed. Mine was also marked as an official DJI part, but the cable wasn't. I ordered two more spare cables just in case. I kinda think they can fail in normal use without crashing. There are some "joints" that seem to be fragile. I'm thinking maybe wind and vibration can damage them over time.Does the plate I ordered already have the rubber bands on then?
I was afraid you'd ask me that. My advice is to watch as many as you can stand. Most have poor imagery, but they know the process. The one with the best imagery was the one that I take exception to one part where he has you fold the cable so that the two halves are more in line with each other. If I recall correctly, that turned out to be incorrect. It went together, but just didn't seem right in the end so i redid it. Take a lot of pictures of how yours is run and duplicate that. Try to delay peeling the adhesive covers until your confident of your work. There are bend lines on the cable, but they aren't completely clear in what you're supposed to do. That's why you want to get the old one out in one piece and pre bend the new one to match. Take your time.Can u point me to the most accurate video as how to replace
It is possible to disconnect the gimbal by posting it to the side and unscrewing the gimbal where it minus to the vibration board. Saves trouble of removing the rubber bands.I tore the rubber supports on the vibration plate...
It took several procedures before I figured out I could just push it over to access the screws.I like the tools. Thanks for pointing out that the camera can be detached from the plate, but I thought the screws ran up from the other side and would be hard to get out with the vibration plate still attached.
