Those are probably the AC DAT logs & will be replaced rolling when memory is full ... no need to try deleting them manually. The AC logs isn't readable by others then staff from DJI. Readup more around flight logs here if you are interested --> Mavic Flight Log Retrieval and Analysis Guide , copied what's said about the AC DAT logs below ...
You can't.How can I turn this continuous CPU and flash storage extensive logging off?
