DJI Go 4.2.22 iOS
InvisibleName
Peterborough, UK
Just flown MA using iPad 2018 & Go 4.2.22. No problems to report. POI trialed and then C button (programmed to recentre gimbal) - worked before & after.
And for those not in the USA, the FCC hack still works ie I still get prompted if I want to change region (and can select cancel)
I would like to see the Intelligent flight modes on the MA remain as your manual settings are set without defaulting to 1920 x 1080. I use 4k 30fps which makes this a P.I.A. to reset each time. It also eats up battery time.
How do you get the update to start - it won't find the update automatically from the DJI Go 4 app nor from IOS Updates?
utahloanrelief
